    • By joe zx
      I have LG oled 55b8pla, it is connected to the net, it has the latest update installed, when I start the web browser application and in the on-screen keyboard I start typing for example the URL of the web page, so instead of the number 1 it displays a number 2, instead of the number 2 a completely different character, etc. etc. etc.
      I turned the TV on/off, turned the app on/off, unregistered the remote and registered it again. No effect so far.
      Any advice, thanks.
    • By netsplit
    • By svsrama
      Sriram.
    • By Ian_AW
      G'day,
      Many apps will bring up an alphabetised layout of keys rather than the more conventional QWERTY keyboard.
      Is there a way of overriding this so that a conventional QWERTY layout can be used?
      Thanks.
    • By Jeffrey Rapp
      I recently purchased an LG OLED48C2AUA. Frankly, I'm not pleased. The biggest problem is searching for programs, particularly across apps. For example, if I'm in Netflix, and search for a program that happens to be in Prime Video, using voice control (Alexa or LG) or the speak button on the remote, I usually get random UTube trailers or other suggestions, or no suggestions at all. It seems I have to know in advance what streaming app it's on, and even that doesn't work all the time. Before purchasing this TV, I used to be able to immediately find the program using the voice control on my Xfinity remote, or the Roku remote (if the program was on a streaming service) and my "unsmart" Sharp TV, with the input set to either cable box or Roku, as appropriate.
      I don't want to have to know in advance what app the program is streaming on to find it. I want to be able to simply say "Alexa, show me "Boardwalk Empire", no matter what program or app the TV is currently tuned to. I want the complete list of possibilities to choose from, particularly since some may be free, depending on my subscriptions. Is this possible?
