UJ701V - no multi-view option
By DW1
By garamja
By ato53
I have a new C4 TV.
Thanks for the follow-up
By Željko2
I own a TV LG oled65c31la.aeu. I am interested in whether it is planned in the next firmware updates to return to multiview the
option of displaying two live channels (antenna dvt2), as it was earlier in webos 2.
Previously, a buffer was created in which terrestrial channels were saved, from where they were marked for display.
By Željko2
Hello everyone.
Thank you.
Ademar
Hi!
I just bought LG UJ701V, don't find it on US site model list, so probably it has a different name in other countries.
Tv has webOs 3.5 (3.7.0-57312), and I was expecting to have multi-view, searched every where and just found on a compare site that this model doesn't have this.
Is there any way to change webOs version to have multi-view available? or any other trick!
