Floating Mode Txt Box--Then Web OS Bird flying
Replaced main board to 65 inch HD tv.  After replaced the screen was with snow and this message was floating across the screen " FACTORY MODE [How to go to user mode] Press Instop Key in a remote control."  I installed AnyMote remote control on my phone and pressed the Instop button on the Service Remote.  The FACTORY MODE  message disappeared and then the screen changed to "web OS and a bird waking up to fly across the screen.  Next the screen appeared--'HERE WE GO" Start, but nothing happens after that.
Please help.  Do not know what to do next.
    • By atcronin
    • By Pranay Mokida
    • By Cody94549
    • By Rayden79
      I'm having this problem with LG Oled 65c16LA with WebOs Version 03.40.85
      When I turn off the TV, it goes into standby mode.
      After 2 minutes the red standby LED turns off and it is no longer possible to turn the TV back on with the remote or with the power on button.
      It is then necessary to unplug the power supply, wait a few minutes and reconnect it.
      So the TV goes back to standby and you can turn it on again. In use everything works.
      Is it a software problem? How can I solve it?
      Thank you
    • By Seppel
      i am in the process of purchasing several LG digital signage displays and need some more information before i place
      my order.
      I need a function like kiosk mode to start a website in full screen mode on device startup.
      The device would be a LG 43UH5N-E installed is webOS.
      Is this posswible with the onboard functionallity of webOS or do i need a 3rd Party App ore something?
      There is no need for a pagerefresh or such things, only display of es simple Website.
      thx for help me out.
