HVEC/H.265 issue
By JasonB
By AMK
Tv model 55UJ630V-TA
Sw version 06.10.50
By jcol5786
A few years ago I bought a 43" LG Model 43UK6200PUA, manufactured in 2018. I'm from Canada but I purchased this TV in the US. It was a store demo unit on for a great price. I took it home to Canada, set the location to Canada and setup up in our bedroom. It has been working fine with our Fiber TV service as well as Netflix, Amazon etc. We also to have a 60" LG TV in the living room which was purchased in Canada. This TV is similar in age to the one in the bedroom. Recently I started watching the LG channels on the living room TV. I hadn't really paid much attention to them before but now I enjoy them. My problem is that the LG channels do not work on the bedroom TV. I suspect because it was purchased in the US but located in Canada. With the location set to Canada the LG channel guide populates and shows what's on however when I select a program I get the following message.
By Phil7108
We recently subscribed to Paramount Plus to catch up on episodes we lost when our COX CONTOUR DVR died. Frequently when streaming an episode,the playback will suddenly freeze. If we try to go back, using the "undo" key, we can sometimes get the playback to resume, but it has rewound abp=out 10 minutes. After resuming playback, it will frequently freeze again. My wife is so frustrated, she wants to cancel Paramount. Any suggestions appreciated!
By Wingwalker
LG Television. Device ID: LG24-K8LPN2 Rowridge transmitter - BH22 (Dorset) I purchased a new LG television last week from Curry's but am having a repeated issue on the Freeview channels. The issue is that despite several attempts at clearing the memory and doing an automatic retune on digital channels - after an overnight switch off, they have all gone again by morning. I can view everything as normal during the daytime - including if the television has been turned off for a number of hours. The issue arises when I turn on the TV the following day after it has been turned off overnight. I am continuously left with just five channels starting at number 301 as per the image below. I have a set top box from BT and have tried retuning the TV both with the box connected, and without. The results are the same each time, no matter what I try. Daytime all is well, but after an overnight period I am left with the screen above. As you can see from the image below, everything is as it should be after yet another retuning session this morning. Please can you help?
antunes20
I recently bought a LG OLED B7 and I'm facing some issues while playing H.265 content. Initially I thought the problem was in the content that I was trying to play, but after some tests I realized that the problem should be in the tv (probably the decoder).
You can check the issue here:
As you can see, sometimes there is a kind of image distortion.
I thought the problem was DLNA, so I tried to reproduce the same content over USB but the problem remains. I asked a friend of mine to reproduce the same content in his Samsung TV and he is not facing any issues at all.
here is some video info about the source
CODEC : HEVC
TYPE : 2160p (Progressive)
FRAME RATE : 23.976 fps
DISPLAY ASPECT RATIO : 16:9
FORMAT PROFILE LEVEL : Main [email protected]@High
BITRATE : 48.3 Mbps
WIDTH x HEIGHT : 3840 x 2160 pixels
COLOR PRIMARIES : BT.2020
AUDIO (1)
CODEC : TrueHD Atmos
LANGUAGE : English
CHANNEL(S) : 7.1
BITRATE : 4769 kbps
SAMPLING RATE : 48 KHz
BIT DEPTH : 24 bits
Does anyone else have this problem?
Thanks in advance
