- 5
gigabit ethernet gigabit ethernet on smart TV
By Will M
By Lesbo
By Rex G
- 2 answers
- 7,956 views
Mihai B.
Is there any way of installing an usb gigabit network adapter on a webos smart TV? The builtin wired adapter is only 100mbps (on a 2000$+ TV, shame on you LG!!!) while the wifi (N) is very poor, with the router at 1m from TV it only gets half the bandwidth of the wired network. Anyway the wired network maxes out near 100mbps but I need more bandwidth as I have 4k video content with bitrates grater than 100mbps which I cannot stream without stuttering to TV through XPLAY/PLEX.
Kind regards,
Top Posters For This Question
12
11
7
6
Popular Days
Sep 12
8
Aug 12
7
Feb 26
6
Feb 27
5
Razielgr 12 posts
Metasyntactic 11 posts
Mihai B. 7 posts
amuk 6 posts
Popular Days
Sep 12 2019
Aug 12 2019
Feb 26 2020
Feb 27 2020
Popular Posts
Morten Vinding Svendsen
But he is talking abort streaming local content, it is not unlikely to be much higher bandwidth: look at the blue ray standard: link hidden, please login to view I LOVE my OLED and WebOS, bu
schneidernet
4K only needs 25mbs. Works fine on my C7.
Absolutely agree. The market for people streaming local content at higher bandwidth than 100Mbps is very slim, and if you deducts the pirates I believe it approximates zero. So LG probably d
Posted Images
136 answers to this question
