FREEZE PROBLEMS WITH SLINGTV
We have been freezing and  video buffering and pixelation. ....we have fast enough internet we have been told but we need to fix speed of wifi through the tv...any help please.....our TV is a LG WEBos UJ6300 55inch
4 answers to this question
Expand
Your UJ6300 has 802.11ac Wi-Fi built in which should be fast enough to stream pretty much anything thrown at it.  The problem may be in other parts of your network, the fault may be with the wireless point the TV connects to.
  On 4/24/2018 at 4:58 AM, nemilose said:
Try to change WiFi channel.
The best option is to temporarily run a LAN cable to your TV, so you can check whether the problem is related to the WiFi connection or your ISP.
Expand
WiFi channel overlap can indeed cause issues, a neighbouring property's network set up could be using the same channel as your router/access points.  Even if your router/access point claims to have automatic channel selection to prevent this happening I would not, in my experience, trust it.  Get a smart phone app such as this one to see what may be causing problems:
 Yes, if you can run a cable to test it is the best way to see if the issue is or isn't WiFi related.
    • By John Nguyen
    • By Nick Payne
    • By LG tv fan
      Recently live channels stopped working with an error every 2-3 seconds.
      Older media is still playing.
      Now I noticed that new media like today's news aren't playing either. Same error.
      News from Friday 3rd may still work.
      Have tried on 2 LG tvs.. Oled from 2018 and LCD from 2020
    • By Christer Ekström
      On my LG OLED65B9SLA TV when using the built in applications (Viaplay, HBO and more) they freeze or stutter.
      I have a good Internet connection (100 Mb) and the problem does not occur when I use the same applications on my Apple TV connected to my LG TV.
      Both have a wired connection to the router.
    • By Trollpaw
      Hello.
      I have an issue with my tv losing connection.
      It seems like it's not uncommon for it to happen from time to time. but is has gotten worse the past couple of months. It can happen several times per day. usually when using netflix, but it can happen whenever.
      i regularly lose the bluetooth connection to my magic remote, and a lot of the times when this happens i also lose connection with the wifi, The remote is still usable, in a somewhat limited capacity(no pointer, and need to have a more clear line of sight to the tv)
      when the wifi disconnects it sometimes connects automatically, sometimes i have to manually connect it again, and sometimes the wifi function gets turned off, and can't be turned on again. usually this solves itself by putting the tv on standby and starting it again. using cable instead of wifi is not possible for the moment.
      the remote. what usually works is pulling the plug on the tv for a while, and then it functions again. sometimes it's enough just putting it in standby mode for a minute or 2. sometimes i have to unregister and re-register the remote. THere's not one thing that works all of the time, so i have to try several things, but i've found that pulling the plug usually works best.
      it's rarely enough to un-register and re-register the remote, i usually have to either put the tv in standby for a couple of minutes, or pull the plug
      it's getting very frustrating dealing with this, so i'm asking to see if anyone knows what to do as a more permanent solution. i have no issue with doing factory resets or anything like that.
      Regards
      Stoffe
