HDMI/ARC completely dead after update to
By mean2
By OliverRC
By Ajothen
By Roy Brown
By atcronin
- 1 reply
- 6,353 views
- 3 answers
- 7,414 views
- 3,329 views
- 14 replies
- 52,160 views
conrad
After my LGOLED55C7 updated to 04.70.85 I have l;ost all sound through ARC.
I have an Arcam AVR550 receiver which works for everything else and used to work perfectly (even with the latest Arcam update that provided Dolby Digital +).
Unfortunately after the TV updated to 04.70.85 I have lost all sound over ARC. The reciever switches to RC as normal when, for example, Netflix is started, It shows Dolby Digital + is being transmitted, but there is NO SOUND.
Any clues?
I have factory reset both the TV and the receiver :-(
6 answers to this question
