Change region & combine apps from different countries?
By thewookiewon
By Pranay Mokida
By MNHL
By Tobin
Tobin
By Sqwazy
TOMillr
I'm looking into buying one of the LG OLED TVs but am not familiar with the WebOS app platform LG uses.
Is it possible to manually switch between country settings to install apps not available on a specific market? Can you somehow combine and run apps from different countries at the same time?
For example, is there a way to download Hulu from the US alongside the BBC iPlayer from the UK?
3 answers to this question
