Have LGUH 7700 Is it possible to factory reset without a remote?
By Horniak
By Dennis Radliff
By Gabriel Śmiech
By ato53
I have a new C4 TV.
Thanks for the follow-up
The Dude
I really blew. It. Was kinda intoxicated. Thought it was a wonderful idea to factory reset my TV. Problem is, I've been without my phys6 remote & been using the LG WEB OS remote. So obviously until it's hooked up to the web I am stuck. It is currently at the "Here we go" screen with "start" directly below it. I can not figure out s way to "start"🙄
Any suggestions?
Thanks!
posted without content.
