  • 1
Software version 04.25.70
What is software version 04.25.70?
We have an 55EF9500 TV. Today we got an update for it, from 04.25.40 (I think) to 04.25.70. Apparently that does not correspond to a WebOS version but I assume it includes a newer version of WebOS. The important thing is, where do I look to see what the new features are?
 describes a new version that has primarily connectivity improvements. Is that what was installed today (in 04.25.70)?
  • Thanks 1
    • By OliverRC
    • By NaveenKumar
    • By majorusa
      - 3.23.24 - Romania- 47LB730v
    • By Steve D B
    • By Ali Zia
