What version?
calgaryx
4 answers to this question
    • By Steve D B
    • By Ali Zia
    • By NaveenKumar
    • By Burkey
      hi all. new to this but really stumped!!! i live in ontario canada and have been using cogeco cable for internet and tv. it got way too expensive so i cancelled both and switched to bell 3.0 which is at least 3 times faster and we have no tv package, so we are just streaming everything for 1/3 the price!!!!!  i signed up for a couple of sports sites, tsn and sportsnet + so i can watch hockey playoffs and other sports.  tsn works just fine on the tv.  however, sportsnet + says that i have to have web os version 89 or higher.  i found my tv, which is a 2023 version, is only version 87!!! i chatted with tech support and they were no help.  anybody got any ideas as to what i can do for this???  no auto software updates for it and nothing on the lg app store.  quite confused how a 2023 model is not up to date, or sportsnet+ is that far ahead and not backward compatible>>>
      thanks to anybody that answers.
      dave
    • By dolbnya
