Amazon App doesn't render in HDR
By netsplit
By Magsing
By svsrama
Sriram.
By Nitin Chopra
Hi Team,
After update of LG WebOS to 04.40.70, Amazon Prime Video app on my LG Smart TV stopped working. It started giving error :
Internet Connectivity Problem
There is an internet connection problem. Check the device's internet settings, data cables, or try to resetting your router. Also, turning your device off, and then back on might fix the problem. For further assistance, please contact Amazon customer service at www.amazon.com/videohelp
The internet/wifi connection is fine and all the other apps are working without any issue on the LG smart TV.
I have even tried uninstalling and reinstalling the Prime video app, but that didn't help.
Has anyone faced this issue ? Is there a solution available for this issue.
Thanks & Regards,
Nitin
By Harish113
Why my 55 Nano 80 TV doesnt have gallary app? I have explored for 2 days no success. Please help me out
- 6 answers
- 5,301 views
- 1,194 views
- 2,926 views
- 9 answers
- 4,634 views
