sound bar sk9y HDMI ARC TV to Sound Bar not working
By Venkata
Hello Team,
By OliverRC
By Roy Brown
By hollean
By Pranay Mokida
- 2,514 views
- 3,163 views
- 51 answers
- 122,363 views
- 4 answers
- 7,588 views
Jose Antonio Campo
Dear Friends ,
Really looking forward to your help and support
My problem is i can not make work the HDMI ARC conection between TV and Sound Bar
So far:
TV LG OLED55B7P-S (latest firmware)
Sound Bar LG SK9Y (latest firmware)
NVidia Shield Pro 2017 (latest firmware in my region, waiting for Oreo)
HD Set Top Box Arris/Motorola (Cable) HDMI
Used the device manager on the WebOS to connect the Sound Bar , assigned HDMI ARC , Simplink , and tried both auto power yes and no, sound test did not work
NVidia shield connected to SK9Y HDMI IN , HDMI OUT (ARC) to TV LG HDMI 2 (ARC)
Works fine image and sound, sound of course is ok as it goes from NVidia to SK9Y directly
HD cable top box to TV LG HDMI 4 and I get no sound from the TV thru the HDMI ARC port (previously establish HDMI 2 (ARC) to sound bar)
I plug in the optical and works fine, Internal tv speakers works fine , BT fine….everything works but the HDMI ARC.
What I am doing wrong? I am worry it may be a HDMI ARC port problem, TV Is about 3 months old, soundbar is about 2 weeks old
Thank you in advance
3 answers to this question
