Firmware 04.05.60
By SHawk
By Sqwazy
By majorusa
- 3.23.24 - Romania- 47LB730v
By сергей фролов
By SailorMoon
Kalsmugglarn
Anyone nows what the new firmware 04.05.60 includes? Lg has the worst homepage ever 🙄
