  • 2
how to add BISS KEY to lg smart tv ?
3 answers to this question
@Ahmed SC You can only add apps to your TV from the LG store supplied to your TV in your country of use.
However, you are about 5 firmware updates behind, as the latest is now  05.31.00, so ensure it IS connected to your home network, and retry the update check.
    • By Will M
    • By Lesbo
