Please help - how to change the default open screen - I dont have live tv
I just bought a lg b7 oled and have a problem. I dont subscribe to cable so I wont ever be using it on this tv. Every time I start the tv it loads the OS and the cable-less static comes on the screen and BLASTS through the speakers. The tiles for netflix, hulu, etc are at the bottom so I choose one of those. How do I stop the tv from defaulting to turning on the "tv" that clearly doesnt exist? Ive tried deleting the tile for live tv, and even moving it to the far right side but still every time I turn n the tv - static with the menu on the bottom.
12 answers to this question
Settings → All Settings → Programme → Programme Tuning and Settings → Programme List Update → Off This issue happens because your TV is trying to search for updates within the TV's channel listings. This was something that was implemented with the latest software versions because the governing body who look after the channels wanted the TV to scan for updates...
  • Thanks 1
Unfortunately I am in America and this is not an option on our menus. I posted this on a few forums and called LG twice. I either have to turn my TV  on to blaring static every time,  or have it turn on to a HDMI input  screen where a pop up window asks if I want to  search for an input every time. The reason LG gave me both times was that a TV is built to use cable, and that won't  be changing any time soon. I will be returning this TV for another brand.
I have a C7, no cable, just like you. Mine has never done what you describe so there must be some option to prevent it. Not entirely sure what it would be, but I have 'Channel Plus' and 'Live Plus' turned off. It defaults to the Home Theater input.
First I had live tv using an antenna. Now I have a set-top box. In the connection manager menu (I think) I told the system I had a set-top box on HDMI-2 and now the TV always starts on HDMI-2.
I have a b7. There are no channel plus or live plus option in any menu.
If I do that it opens to a pop up screen asking if I want to search inputs.
i got this reply on my post, not sure if its relevant to you but:
I FINALLY found a fix for this. Well, really a workaround, but it solved the problem for me. I went into parental settings and set a passcode lock on the live tv and component inputs. Now, my tv starts up perfectly on whatever HDMI input I last used.
In Device Connector I selected 'decoder'. After this I also changed the functions of the Magic Remote.
Now I select 'Input' I can see the live TV is still selectable, but al the options are grey.
Also in 'setup' I can not select channels any more.
Of course I don't remember exactly what I have done 2 years ago, or maybe they have changed the options in newer version of WebOS. The only thing I can think of is reseting the TV and while going to the options select you don't have an antenna.
    • By crct
      Driven by the rapid advancement of AI technologies, the data center construction market is expected to grow continuously over the next decade and possibly beyond.* AI data centers, with their intensive usage of high-powered chips, place greater demands on electricity and water resources and produce more heat than conventional data centers. For these reasons, energy-efficient thermal management solutions have emerged as critical infrastructure components for AI data centers – essential for keeping their servers at the optimal temperature and for minimizing their environmental impacts.
      Conventional data centers typically utilize cooling towers to control internal temperatures. However, this method consumes large amounts of water – an increasingly critical concern given the growing threat of global water scarcity. A report from the World Resources Institute highlights that 25 countries currently experience extreme water stress each year, a number projected to double to 51 by 2050, impacting approximately 31 percent of the global population.
      In response, AI data center operators are turning to more sustainable, water-efficient cooling solutions. Technologies such as air-cooled chillers (ACC) and direct-to-chip (D2C) cooling solutions are gaining traction as smart alternatives that minimize water usage without sacrificing performance.
      At the
      link hidden, please login to view in Washington, D.C., LG showcased its latest lineup of sustainable cooling solutions. Leveraging its deep expertise in HVAC technology, LG is helping to shape a greener future for the data center industry.
      An integral part of LG’s comprehensive suite of data center solutions is the ACC, which employs high-efficiency core components and low Global Warming Potential refrigerants to deliver a remarkable performance with fewer emissions and lower energy consumption. Available in both inverter screw and oil-free centrifugal types, the innovative ACC offers enhanced cooling capability with its “free-cooling” system that leverages a pumped refrigerant economizer to cut down on energy and water use.
      LG has also introduced highly efficient D2C cooling solutions, such as its Cold Plate. When combined with an ACC, this solution is capable of implementing targeted heat removal to help reduce water usage. The system attaches directly to server chips, using a liquid coolant to absorb the heat and channel it through a closed-loop system managed by the Coolant Distribution Unit (CDU). The CDU features AI virtual sensors for full redundancy and boasts a compact, modular design for easy maintenance and installation.
      To create the next generation of data center cooling solutions, LG opened a dedicated AIDC testing facility earlier this year at its LG AI Data Center HVAC Solution Lab. The lab is capable of conducting real-world simulations of data center environments, helping LG fine-tune its systems to meet evolving customer and environmental demands.
      Through its ongoing research and innovation, LG is reinforcing its position as a global leader in sustainable data center cooling. By delivering solutions that cut energy use, reduce water consumption and maximize performance, LG is committed to supporting both the future of AI and the health of our planet.
      * According to , the size of the global data center construction market is estimated at USD 258.56 billion in 2025 and is forecasted to reach around USD 491.99 billion by 2034, accelerating at a CAGR of 7.41 percent from 2025 to 2034.
    • By DWINKS49
    • By Batman
