Permanently Delete Apps
Is there a way to permanently delete apps to free up both ROM and RAM?  Uninstalling does not do it to allow for your TV response time to improve. A regular reset also fails to accomplish it. Will a factory reset produce the desired results?
    • By thewookiewon
    • By Pranay Mokida
    • By MNHL
    • By Tobin
      Tobin
    • By Luka Pantsulaia
