OMG - this just started on my tv 8/7/23 and I've had my tv over a year. I've unplugged my router, my wi-fi but have not unplugged the tv itself.  It's disgusting to watch tv with this flashing off/on. I do not have cable tv.
  • 3 weeks later...
I think mine just started around the same time.   Like an above poster for a long while it was just a remote pointer that would not work.   Then started getting the audio pauses when streaming video now getting the wired lan disconnected and connected messages and Wi-Fi turned off an audio freeze is much more frequently for the past few weeks.    I guess I have to check my warranty see if I can get a repair guy I don't know if they got to replace the power supply or the network card or wtf is going on.  My last firmware updated my TV was back in June not sure if that's related or not this feels like a hardware issue to me.
On 5/26/2020 at 5:46 AM, Daniel Ng said:
I had this issue for a while... it started off with the mouse pointer not working... then youtube video stutter and the popup coming up on and off more and more frequent. I had the TV wired through a 1 Meter cat5e cable to Dlink Gigabit Switch which is then connected through a 10Meter cat5e cable to the Router. I changed the switch to a TPLink unmanaged Pro switch and toggled the port to 100MF and it was alleviating the issue for a while before it get bad again. Then I swap out the 1Meter cable from a CAT5e to CAT6 and surprisingly, the problem goes away. It looks like the cable might have gotten bad over time.
I have the same exact issues and symptoms you describe for months now except that Wi-Fi is even worse than the ethernet.
I found half a fix that is a solution for me.     I saw in a youtube video a guy who took apart his tv and fiddles with the ribbon that connects the wifi and IR to the circuit board.   He said to cut off the tape and flatten it out since LG literally tapes the ribbons together and then folds them in half.   So i did just that and now my wifi and magic remote pointer work which for a long while now I could not get to work at all it would keep going in and out randomly.   Unfortunately this did not help the problem with the ethernet going in and out.  That is still a problem so I just unplugged ethernet cable and now I'm using wifi and the remote works.  I'll take it.    We'll see how long this lasts.   Obviously something happened to either the cpu board or the power supply board and I have no idea which is the culprit.   The other things I did was remove the wire connecting them both and reconnecting but I'm leaning it towards being a problem with the main cpu board which has the ethernet jack on it.
For all I know the remote and wifi not working  are a separate issue from the wired lan not working.   But I've read in this thread others who have both problems this might be a solution for you.    Look up Charles Yamabe on youtube.  With the video titled:   "How to fix the wifi on a LG TV (Wifi is turned off error)"
  • 5 weeks later...
On 11/3/2019 at 1:16 PM, Tider said:
Has anyone done a hard reset on the tv to see if it helped any?
I've done the requisite hard reset - the problem remains. I have also contacted LG support. They refuse to acknowledge this is an issue.  It stated with a firmware update back in 2018 and remains a problem to THIS day. I will never buy an LG product again, any product.
see the above method.  I've also seen some other posts in the thread earlier already saying this worked for them.   You have to take your tv apart.   Then you will see the ribbon with the plug lavbeld wifi/IR    unplug it and carefully cut the tape off it and flatten the ribbon out as best you can then plug it back in and put the tv back.   Thats what what fixed my wifi connection,  and my magic remote.  lol..
I have a 50" LG TV I got second hand. It's great, the apps, etc don't really work, have no manual, it's fine with YouTube, Netflix, Disney+, etc. But it has a severely annoying pop up on the screen that says "wired Lan cable disconnected" I've tried manually adjusting settings, works for a bit, then comes back. Wireless works fine, it's not unplugged (or plugged) into anything other than power and DVD player. Very annoying, how do you fix this? Don't want to spend alot, if anything, and if I do, I'll just go buy another second hand tv, but shouldn't have to. Been reading it's a common problem, so why doesn't LG fix it? I got it second hand, so can't get a technician in on warranty, doesn't matter if it's a DVD movie or YouTube app ( I don't have cable TV service) the pop up still comes up.... Does anything work? I've reset the TV a number of times, that pop up just keeps coming up ! How do you do a firmware update? Don't think that would work, tho, as a few people said they tried that...
Any suggestions or fixes ???
Thanks 😊
On 8/17/2019 at 2:44 PM, Tider said:
I called LG customer service and they wanted  me to do a total reset on the tv.   I was  afraid it would wipe out my calibration that was done by a professional calibrator , so I didn’t try it.
There has had to be some solution.
It doesn't help anyway
... my tv is still doing the. Pop up and I reset everything.
Posted (edited)
If you read through this entire thread, you will find that the only reliable fix that people have found is opening the TV and moving or just spraying the ribbon cable ends. I did this over a year ago and still is working fine. Admittedly this is an extreme measure for some people, but there are YouTube videos that show how to do it. My original post is: https://www.lgwebos.com/topic/3520-popup-messages-wired-lan-cable-disconnected-wired-network-is-connected/?do=findComment&comment=24874
Read serveral of the posts that just preceed mine and you will see many other people had good results. The only downside is that you have to be willing to risk damaging your TV, but in my case, I was willing to pay for a replacement TV to get rid of the problem, so this solution avoided buying a new TV.
Edited by Philip Heavin
Nope - not doing that. And I'm never buying another LG product again.
well all tvs have similar problems.  but at least there is a posted fix for the LG.   In fact I just tried to take apart my sisters vizio tv,  and the ports and plugs aren't even labeled in there lol.  I felt the same as you though before I fixed the LG.
I have an LG TV and for the last year at least have always had this problem re the lan cable disconnect / reconnected.  What amazes me is that there has been almost no response from LG itself to either explain the problem and how to fix it or issue a firmware fix. As I also have had many other problems with the T V remote and the webos I certainly will not buy an LG TV again.
I told you how to fix it above.  its amazing you are just ignoring my post and didn't even read the thread.
You are amazing. how did you know I ignored your post and did not read your thread?  If you read earlier post you will see that others have done what you have done, but the fault remained, as I found out (!!!)
It's only one way, because it's hardware problem, not software. See my earlier post with solution. It's super easy.
oh, you can THINK this is a hardware problem but MY problem with the constant LAN disconnects STARTED after a firmware update!
you think so?  My Samsung TV's, 4 of them have NEVER had ANY issues whatsoever. I got this LG TV because I couldn't argue with the price: A 55" model for $129 at BestBuy and it was NEW.
Sure.  your samsung tv's last forever thats why you bought LG.  I believe ya.  honestly I do.  lmao...
I thought that too until I tried the above fix.
  • 4 weeks later...
This “fix’ to add 8.8.8.8 is crap.. I run pi-hole dns on my local network and have for yrs. This wired lan  dis and connect only started after a LG firmware update about yr ago. I am not willing to switch dns or to go to wireless.
they broke with an update they can fix it for real with another. Don’t want a work around, just want it to do what it should.
  • 2 months later...
Posted (edited)
Finally found something that worked (rather than the usual, reset your tv/router nonsense)
Remove back case of tv and you may well see the problem. Kinked and twisted ribbons leading from the WiFi module. CAREFULLY flatten these out. This fixed the wifi AND the intermittent Lan connection issue.
Edited by Richy Ho
Added you tube video
This is indeed the only fix no matter how many stubborn posters are in denial above, But for me it was only temporary.  After 5 months I had to do it again But I also just bought a fire stick to avoid the issue totally in the future.
I did this fix almost 2 years ago and posted here back in March 2022. So far the fix is holding and I am next to the ocean where the salt air ruins electronics quickly. Of course I didn't appreciate needing tear apart my TV, but other than that I like everything else about it.
    • By akhil7j
      First in the 5G Private Network Industry to Receive Domestic Network
      Equipment Certification from Korea Association of Network Industries
      SEOUL, Sep. 26, 2024 — LG Electronics (LG) is stepping up its presence in the 5G private network market, a key infrastructure for future industries. The company has recently achieved a significant milestone by becoming the first in 5G private network industry to receive the “Domestic Network Equipment Certification” from the Korea Association of Network Industries for its self-developed 5G private network solution.
      The “Domestic Network Equipment Certification” is awarded to products that are developed and manufactured in South Korea, a key credential for supplying to public institutions. This certification marks LG’s official recognition for internalizing core 5G private network technologies.
      A 5G private network is a customized network deployed in specific areas like factories and buildings, offering high-speed data transmission and exceptional stability. It serves as a vital foundation for innovations such as digital and AI transformation (DX/AX) and smart factory operations.
      LG’s certified 5G private network solution leverages advanced software to handle network functions typically managed by traditional 5G equipment like Radio Access Network (RAN) and 5G Core. This software-based approach allows for faster data processing and improved stability, with the added benefit of enabling upgrades without hardware replacement, significantly lowering operational costs.
      Harnessing its strong software capabilities, LG’s solution delivers a customized 5G private network tailored to meet diverse client needs and installation environments. For instance, it can create secure, isolated networks for clients with high-security requirements or integrate external cloud services for companies that require frequent collaboration with external partners.
      In addition to network setup, LG’s solution offers a device control platform for seamless management of connected devices. This includes LG’s own products, such as robots and digital signage, as well as clients’ existing equipment like CCTV and smart safety devices, all integrated via the 5G private network.
      With the momentum from this domestic certification, LG plans to actively pursue both enterprise-focused and public 5G private network initiatives, targeting sectors like smart factories and more.
      Recognizing the immense potential of the 5G private network market, LG has committed significant resources to technology development. The company holds around 30,000 telecommunications patents, including many related to 5G, ranking it among the world’s top innovators. Last year, LG formally added “facilities-based telecommunications business” to its portfolio, positioning itself for full-scale commercialization of its 5G solutions.
      LG also brings extensive real-world experience, having tested its 5G private network solution at various reference sites, including its Tennessee factory, a smart factory in Chungbuk, a logistics center in Incheon and a university hospital in Seoul.
      The global 5G private network market is expected to grow rapidly, from approximately USD 2 billion in 2023 to around USD 11.8 billion by 2028, with a projected annual growth rate exceeding 40 percent, according to market research firm MarketsandMarkets.
      “We will continue to provide customized 5G private network solutions for clients who need fast, stable networks, leveraging our outstanding 5G technology and operational expertise, accumulated in various sectors such as factories, logistics centers and hospitals,” said Lee Jun-sung, vice president and head of LG’s Private Network Business Development Department.
    • By forum1
      My LG 49UB850V LED TV  browser is too old. The most of the pages not work any more. How to easy update just one simple browser app? For example, often browser show error during open new page. It show certificate expire problem and page not load at all.
      This mean LG sell product without update at least browser certificate and now we are stuck and can not even load one page from WWW.
      Shame on you LG. I will not buy any more from you.  How dificolt is to release new update to update OS certificates? Microsoft Windows did this, android did also for old phones, etc... Really, can not undestend this asian people from Korea.
      Partnership to Enhance Company’s High-performance Heat Pump Solutions for Cold Climates,
      Lay Groundwork for the Development of Next-generation Technologies
      SEOUL, Sep. 3, 2024 — LG Electronics (LG) is completing its global R&D triangle with the establishment of the Chinese Consortium for Advanced Heat Pump Research (CCAHR) in Harbin. The consortium, which joins existing LG-led initiatives in North America and Europe, will develop next-generation core technologies for heating, ventilation and air conditioning (HVAC) solutions capable of providing strong, dependable performance in extreme cold conditions.
      To mark the official launch of CCAHR, LG held a signing ceremony on August 31 (local time) at Harbin Institute of Technology in Harbin, China. Prominent members of the consortium include the Harbin Institute of Technology (HIT), Shanghai Jiao Tong University (SJTU) and Xi’an Jiao Tong University (XJTU), all of which are actively researching HVAC technologies and systems designed for cold climates. The consortium will operate new research facilities in Harbin and Mohe City to develop strong and reliable HVAC solutions, helping LG to deliver products customized to local needs, and strengthen its presence in the Chinese market.
      Harbin, known for its harsh winter conditions, and Mohe, where temperatures can drop to below minus 50 degrees Celsius, provide ideal settings for advancing LG’s research into heat pump technologies that can maintain high efficiency in severely cold climates. CCHAR will conduct tests on the company’s HVAC solutions, including residential air conditioners, at two facilities: a university-owned building at the Harbin Institute of Technology campus, and a residential site in Mohe. The consortium will gather comprehensive operational data to improve the heating performance, energy efficiency and overall reliability of LG’s HVAC products.
      CCAHR is a significant addition to LG’s growing international program of heat pump R&D collaboration, complementing LG-led consortiums established in Korea and the U.S. last November, and in Europe this June. With its trio of consortiums, LG has built a robust R&D infrastructure spanning North America, Europe and Asia, and will be able to develop technologies suited to the unique demands of each region’s climatic and housing conditions. The R&D triangle will play a major role in further solidifying the company’s global leadership in HVAC technology.
      Moreover, during a recent CEO-led
      link hidden, please login to view, LG outlined four key strategies for business portfolio innovation, including the acceleration of its B2B capabilities – particularly in the area of HVAC. By leveraging its advanced inverter, heat pump and chiller technologies, LG aims to lead the market in high-efficiency HVAC solutions, while actively targeting the growing demand for cooling systems, especially in AI data centers. Additionally, in key markets, LG’s HVAC business is establishing a locally self-sufficient operation system encompassing the in-house production of core components and the creation of production bases optimized for regional supply. This system, which covers everything from R&D to sales and maintenance, greatly enhances LG’s B2B capabilities and is expected to support meaningful long-term growth.
      “We are committed to developing next-generation heat pump technologies tailored to diverse climates,” said James Lee, head of the Air Solution Business Unit at LG Electronics Home Appliance & Air Solution Company. “Through our R&D initiatives, we will strengthen our ability to provide differentiated solutions for each region, and reinforce our product and technology leadership in the global HVAC market.”
      Huntington, W.Va., Aug. 26, 2024 – Marshall Health Network, Inc., a leading West Virginia-based academic health system, announces a new digital health collaboration with Primefocus Health. Together, they plan to offer a customized healthcare service solution to address key regional healthcare issues such as rural healthcare access, obesity, healthy aging and substance abuse.
      Primefocus Health, which launched earlier this year in collaboration with LG NOVA, the LG Electronics North America Innovation Center, aims to enable providers to deliver a personalized, complete care experience and improve access to quality healthcare, which is particularly important in rural communities. The Primefocus Health platform will help Marshall Health Network meet the needs of 1.4 million residents across 40 counties in West Virginia, southern Ohio and eastern Kentucky.
      This new provider-focused, patient-centric healthcare solution will use innovative, non-invasive technology and remote monitoring capabilities to understand patient progress for multiple medical conditions and deliver healthcare therapies directly to patients in their homes. The solution will help healthcare providers effectively manage outcomes and provide assistance, guidance, communication and intervention via the internet, through an app-based patient portal to deliver quality care to patients.
      Primefocus Health will start the collaboration with Marshall Health Network in September, with development throughout the next year and a planned patient rollout in 2025.
      The collaboration between Marshall Health Network and Primefocus is focused on delivering solutions that improve patients’ health through a remote healthcare solution that addresses:
      Rural Health: Enhance healthcare delivery in rural areas by enabling greater access to healthcare. Obesity: Help reduce obesity rates by using technology to promote nutrition, education, physical activity programs and behavioral health support. Healthy Aging: Promote healthy aging by utilizing technology solutions that offer greater access to preventive care, chronic disease management and wellness initiatives tailored to the needs of older adults. Substance Use Disorder: Expand access to evidence-based treatments and support services for individuals struggling with substance use disorder, with a focus on opioid addiction and recovery resources. “We value this new collaboration that empowers patients to have greater access and participate in their daily health care. These convenient services and tools allow patients to receive the right care, at the right time, in the right setting to achieve better outcomes and quality of life,” said Marshall Health Network CEO Kevin W. Yingling, R.Ph., M.D. “Our work with Primefocus Health supports access to comprehensive healthcare services leading to better patient outcomes.”
      “We’re on the path to transform healthcare by giving people greater access to personalized care, empowering them to take an active role in improving their health,” said Darren Sabo, CEO of Primefocus Health. “Working with Marshall Health Network enables us to be front and center in tackling key healthcare issues of West Virginia and rural Appalachia, as we build out solutions to best fit and serve people’s needs and get them access to care that will help them live healthier and better lives.”
