Help I cant install netflix on my smart tv
By anna groove
By Will M
By Lesbo
Basant Gurung
Hey I just brought the 43LJ554T and when I click on netflix app on the remote it redirects me to the lg content store but it says content is unavailable. This function is not available,any fix? by the way amazon video works fine.
