Roku+ disconnects - no signal
By andreluigo
I used to extend my screen from PC/Notebook to my TV but i stayed a long period without do it.
It happens that since a few days ago i am needing it and for my surprise is not working anymore. Tried other cables, updated the drivers and O.S. but nothing worked. So i decided test at the room's TV (LG as well) and worked perfetcly.
I looked for all internet and youtube for similar issues and a solution but couldn't find it, until i receive my weekly mail from this forum and remembered it.
I am suspicious that was one of the several updates since i extended for the last time that made this!
So, does anybody could help me, please?
Thanks in advance!
By Marco Coletti
See topic title. I have an Android box connected to HDMI 1 and would like to check if it auto switches frame rate according to the current video file.
Is there any "secret code"?
OLED48CX3LB with webOS 5.4.3-36 fw 04.41.45
By haptrail
I have an LG C2 Web OS TV and a Roku Ultra Model 4670RW. The Roku comes with an option called "1-touch play" which allows you to switch the TV from between devices connected to other HDMI 2.1 inputs. I have a Roku in one input, a DVD player in another, and a Directv Streaming box in another. With this same setup on a Vizio V435-H11 TV, I am able to press the home/play buttons on the Roku remote and no matter which input I'm watching, it will switch to the Roku. Same with pressing remote buttons on the DVD player and Directv remotes - the TV will switch to that device. But with the LG C2 TV, none of the switching takes place when pressing the same buttons on the remotes for the other devices. I have enabled the "1-touch play" on the Roku remote (settings/system/control other devices/1-touch play), and I have enabled the IR Setup (settings/Remotes & Devices/Remotes/Enhanced Voice Remote/Setup Remote for TV Control/IR setup). I cannot enable the CEC setup on the Roku Remote, but that doesn't affect the 1-touch play switching function on the Vizio TV so I don't think that plays into the limitation on the LG C2. I have also enabled the CEC (Simplink) function on the LG C2 (General/Devices/HDMI Settings/Simplink (HDMI-CEC)). I've read some solutions online and have done a system restart on the Roku as well as disconnecting all devices from power, disconnecting all the HDMI cables, waiting 5 minutes, and reconnecting all. I am using all new 2.1 HDMI compatible cables. Any body else having this problem with using a Roku Ultra and an LG C2 TV and found a solution? Thanks! -
By M55
I am trying to setup my new Phonak my hearing aids TV Connector with my new LG GP2 TV and Sonos Arc sound bar, connected by via the HDMI eArc port. The TV automatically uses the the HDMI eArc port, and that port only. As a result no signal goes through the optical out port of the LG TV.
Is there a way to make the LG TV sound signal simultaneously go out to both the sonud bar via eArc port and to the Phak TV Connector via the optical out port so that I can connect hearing aids to the Phonak TV connector and also use the Sonos Arc soundbar at the same time?
Appreciate any guidance.
Thanks, M55
By Hg-07
Hi!
Does anyone know how to select only a specific art collection as the screensaver? It seems you can select one or more to play manually, but the screensaver that comes on when there is no signal appears to automatically play all of them even if you have set it to play specific ones manually. Moreover you cannot delete the default ones either... I just want a specific theme not a hodgepodge of random works that LG considers "masterpieces"...
dwsteele41
Roku stick + will work through the menu choice, but when any app content starts to stream, I get a "no signal detected" message. Any ideas?
4 answers to this question
