Sun nxt app is not getting loaded
Please update sun nxt app.. It just shows a blank screen.. No contents are loading up.. My net connection is 20 mbps.. Problem has to be with the app as other apps works fine with the connection
Is this an actual app or the web page?
    • By SailorMoon
    • By DeBC
      Anyone looking at getting a LG TV I would recommend look to different company. LG do not provide any good webOS TV support
    • By DaniS
      I reset my location which in turn made me have to accept the terms and conditions however every time I try to load them it tells me I have to download them to which I say okay but then it tells me there’s an error and I can’t download them. I haven’t been able to use my apps or anything for two hours. I reset by tv completely and it still won’t let me. Pls help
    • By Војин Петровић
      Hello... I just purchased LG 43UQ81003LB Smart TV 43" 4K Ultra HD DVB-T2, and in setup I try to agree on 4 displayed agreements. Clicked on "select all" and then clicked Agree button... and it closes and like nothing happens, it is still asking me whatever app i try to run to agree first... what can I do?
    • By Yuvarajan
      I have installed Aha app today and noticed sound output is not coming in dolby format. How to change sound output to Dolby format?
