Lg OLED65E7P Remote
By u84six
By Damian1
After searching high & low, & also on the difficult to navigate LG website, I can't find which magic remote is compatible for my TV.
The model.of my LG TV is - 32LQ630B6LA
Can anybody assist, please?
Many thanks.
By leodavid
I've recently purchased a WebOS TV UK6400PVC and magic remote came with it. The software version is 4.10.30.
The buttons work fine but for some reason, I can't get the cursor to appear on screen.
Appreciate the help. Thanks
- 0 replies
- 273 views
- 1 answer
- 2,559 views
- 4,721 views
- 4 replies
- 6,356 views
Carlos Hernandez
Hello all, I'm new to the forum, this question might be a silly one but oh well, so I bought a Lg OLED65E7P, I don't use the remote often but I do use the webOS LG TV PLUS remote app on my apple iPhone x, on the app remote there's no option to turn on the tv, but there is an option to turn it off, has anyone experienced this as well? it makes it a little inconvenient to always have to turn on the tv via Apple TV 4k trigger, is there a way I can turn on the tv from the lg WebOS remote app?
Link to comment
Share on other sites
