New Quick Menu (2.0)
By denisuu
Hi all,
I'm wondering how you can get into the service menu (In Start) on an old LG Smart TV (42LB630V) running WebOS 1.4. I have a Samsung Galaxy S6 (SM-G920F) with a IR blaster, I have tried sending '0x04FB 0xFB04' to I which should be IR code to enter the menu, but that doesn't work.
By Cedric
Since my TV updated to the last WebOS firmware 05.20.08, quick access key (Long Press 1 for HDMI1, Long press 2 for HDMI2) are reset each time i shutdown the TV, and i have to set them after each reboot...
I tried to restore the factory default settings on the TV to see if there is any change, but sadly this didn't fixed my problem.
Any idea please ?
By pattox
It is easy to add a new item to the quick settings side menu on an lg c2, as long as the item you want is shown on the list presented when you choose the + add item. If you want to add a "shortcut" to an item that is not on the list then how can that be done. Is it possible to edit the list presented?
Specifically I want to add a shortcut to "subtitles on" which is buried deep in accessibility settings, there nothing on the list of options presented to allow this.
By petersteinmeijer
Hello
I keep getting this bar ( see below ) about twice a week. It doesn't require me to do something as far as I can tell. When I close it it disappears only to pop-up again two days later.
Am I supposed to do something ? If not how do I get rid of it ? It is very annoying.
My tv isn't the latest model. LG webOS TV UM 7100PLB
By eks1910
I'm trying to figure out how tp add and remove content/devices from the "Quick Card" section of the "Home" screen on my UR9000 smart TV.
The attached photo shows what it looks like, and I would like to remove "Sports", "Home Office", "Game", and "Music" and replace them with inputs devices that I can quickly access, like "HDMI FireTV", HDMI DVD-Blu-Ray", and "Antenna"
Does anyone know how to edit this so I can add all those so they all show up on my "Home" screen?
Andrea Tedesco
Dear All,
I saw on new WebOS 3.5/4.0 is available this feature New Quick Menu (2.0)
On official LG website.com you can see how is possibile to do like provides editable welcome message, date/time and other frequently used menus in the form of bar, etc..
The question is, do you know the specs of resolution, format, dimension related to the supported contentents (logo/image) in the New Quick Menu (2.0)?
Thank you
