Firmware Downgrade LG 49UJ651v-TA
By SHawk
By Sqwazy
By majorusa
- 3.23.24 - Romania- 47LB730v
By сергей фролов
By SailorMoon
- 8 replies
- 35,744 views
- 0 replies
- 16,629 views
- 0 replies
- 2,083 views
- 17 answers
- 23,700 views
Nomee Sahu
Hello, Since the recent update 04.70.85, my TV's internal speakers are not working. Is it possible to downgrade firmware? If yes, Can Some body share download link of previous firmware for above mentioned model (UAE). Or is there any way to re-flash existing firmware?
Thanks in advance
