Amazon Video not Working
By Roy Brown
By Rex G
By murastefano
How to show video cover art on SmartShare on WebOS ?
I have many movies, mp4 or mkv file with cover art muxed, but SmartShare
By sudar shan
By NaveenKumar
Latest version of sun NXT app version 8.0.20 is not working for web os Tv version 4.4.2-11 plz do the needful full & Airtel Xstream is not found in your web os platform kindly check on that too
jbintn
Amazon Video won't open on my 65SJ8000. I can press the Amazon button on the remote or select Amazon Prime Video from the "recents" menu, but all I get is a black screen. Netflix works fine, YouTube TV works fine, as do all other apps. It's only Amazon video. It's apparently been this way for several days (I was gone over the weekend but my daughter said it didn't work then, either.) It has the latest firmware update. I couldn't tell you the last time I successfully used it, but it wasn't too long ago. I can't remember if it was before or after I updated the firmware, though, that it last worked.
