Coax port on 50GA6400 and other Google TV's disabled in final firmware download
Still waiting for someone in LG support to come up with a fix for the diabled COAX port on all the Google TV's that were disabled in the final
firmware release resulting in the inability to use that hardware for Over the Air reception of free HD channels. Was planning on cutting the cord with
my cable provider and its like sombody came along and as a final farewell cut of one of my arms or legs!
Very irresponsible of LG and GOOGLE!!!!!
    • By StefanosBand
    • By Cody LUEN
      Hi!
      Version: 23.20.36
    • By Rizwan Sumra
    • By starwoodtech
    • By pivotCE
      Tools for the Job
      – Needle nose pliers/tweezers
      – Flush cuts
      – Painter’s and kapton tape
      Trim the USB C Board
      Tape the USB C Board
      Where To Get Power and Data
      Put the Pieces Together
      Congrats, You Now Have USB C
      #webOS4ever
