Surround Sound Won't Work!
I have an LG tv running webos 04.70.45 and I try to connect it to my home theatre system, which is set up for surround sound, but it's only giving dual channel audio rather than 5.1 surround sound. And when i check in settings the option for surrund sound is greyed out, as if it's not possible, has anyone else ecxperienced this issue?
    • By David Daul
    • By Horniak
    • By CJ Catalano
    • By JRay
    • By Pranay Mokida
