Input Select jumps to Live-TV without using remote
By Horniak
By mean2
By RJ Fischer
By hollean
- 1 reply
- 4,819 views
MAUICUDA
Hardware: LG OLED55B7P, and Spectrum Cable box. When I use the Spectrum remote to select "GUIDE"; so I can details about program before selecting to RECORD - whenever I push the Spectrum remote button that says "Guide", the TV at the same time changes my normal input from HDMI to "Live TV".
This is a new problem; am not sure when it started. Will I have to do the LG download again?
3 answers to this question
