3 answers to this question
Posted (edited)
@Assem elmurr
See this:
If you are below firmware 05.80.03, then you will not have this useful fix (especially item 3):
1. Improvement regarding Netflix usability have been applied.
2. Addition of satellite channels and feature updates in certain countries. (Russia/CIS country)
3. IPv6 connection feature on/off can be selected from Network/Wired Connection settings. ***
4. also, minor bugs are fixed.
Note that the latest version is 05.80.60 so best to get that version, using the USB stick method, reboot TV,
go to the network settings, and you might find that turning the IPV6 to OFF will fix it up, as most home networks
don't need/use IPV6, IPV4 works just fine (sometimes IPV6, if active, can cause odd technical issues).
Are you using the inbuilt WiFi dongle, or a direct LAN cable connection from your router by the way, or those IP over mains power plugs with LAN cables? If the latter, some are glitchy and need re-pairing often, and do NOT like going into those multi socket strips. To be sure all is well if LAN connected,try a laptop on the network cable used for the TV, to be sure it works, before messing with the TV settings.
Edited by td47
Typo
    • By akhil7j
    • By Marko00
      only with cancel button.
      How to fix it?
    • By leader6234
      Hey guys !!!
      Thanks in advance !!!
    • By Muser
      First in the 5G Private Network Industry to Receive Domestic Network
      Equipment Certification from Korea Association of Network Industries
      SEOUL, Sep. 26, 2024 — LG Electronics (LG) is stepping up its presence in the 5G private network market, a key infrastructure for future industries. The company has recently achieved a significant milestone by becoming the first in 5G private network industry to receive the “Domestic Network Equipment Certification” from the Korea Association of Network Industries for its self-developed 5G private network solution.
      The “Domestic Network Equipment Certification” is awarded to products that are developed and manufactured in South Korea, a key credential for supplying to public institutions. This certification marks LG’s official recognition for internalizing core 5G private network technologies.
      A 5G private network is a customized network deployed in specific areas like factories and buildings, offering high-speed data transmission and exceptional stability. It serves as a vital foundation for innovations such as digital and AI transformation (DX/AX) and smart factory operations.
      LG’s certified 5G private network solution leverages advanced software to handle network functions typically managed by traditional 5G equipment like Radio Access Network (RAN) and 5G Core. This software-based approach allows for faster data processing and improved stability, with the added benefit of enabling upgrades without hardware replacement, significantly lowering operational costs.
      Harnessing its strong software capabilities, LG’s solution delivers a customized 5G private network tailored to meet diverse client needs and installation environments. For instance, it can create secure, isolated networks for clients with high-security requirements or integrate external cloud services for companies that require frequent collaboration with external partners.
      In addition to network setup, LG’s solution offers a device control platform for seamless management of connected devices. This includes LG’s own products, such as robots and digital signage, as well as clients’ existing equipment like CCTV and smart safety devices, all integrated via the 5G private network.
      With the momentum from this domestic certification, LG plans to actively pursue both enterprise-focused and public 5G private network initiatives, targeting sectors like smart factories and more.
      Recognizing the immense potential of the 5G private network market, LG has committed significant resources to technology development. The company holds around 30,000 telecommunications patents, including many related to 5G, ranking it among the world’s top innovators. Last year, LG formally added “facilities-based telecommunications business” to its portfolio, positioning itself for full-scale commercialization of its 5G solutions.
      LG also brings extensive real-world experience, having tested its 5G private network solution at various reference sites, including its Tennessee factory, a smart factory in Chungbuk, a logistics center in Incheon and a university hospital in Seoul.
      The global 5G private network market is expected to grow rapidly, from approximately USD 2 billion in 2023 to around USD 11.8 billion by 2028, with a projected annual growth rate exceeding 40 percent, according to market research firm MarketsandMarkets.
      “We will continue to provide customized 5G private network solutions for clients who need fast, stable networks, leveraging our outstanding 5G technology and operational expertise, accumulated in various sectors such as factories, logistics centers and hospitals,” said Lee Jun-sung, vice president and head of LG’s Private Network Business Development Department.
