I downloaded the Bing Map app on my pixi plus. Glad to see that HP is not forgetting about legacy and older devices. It also installed enyo, which could mean some enyo apps for older devices?
  • 1 month later...
    • By Junaid Ahmed
    • By Ganesh R
      Hi LG Team,
      Regards,
      Ganesh R
    • By Nishant singh
      Hi Team
    • By Gabor Monzak
      The LG Gallery is a very nice application, I use it many times, but unfortunately there are few classical paintings. Unfortunately, uploaded user images are represented by a variety of transitions and animations, which greatly worsens the artwork.
      It would be good if:
      - The number of factory-downloadable images would increase to multiple
      - Simply display user UHD images without any crossover animation (get the effect on and off)
      - It would be possible to play back-up images in random order.
