Same issue here. I first noticed my issue when I tried to open Sling TV app. It required an update which tried to take me to the LG Content Store. Then I would get an error message that the LG Content Store is temporarily unavailable, try again later. This has been going on for a month with absolutely no help from LG Technical Support. Most other apps (Netflix , Amazon Video, etc.) all work fine. I was finally able to get into my router management and disable the firewall while I tried to update the Sling app. It worked long enough to update the app. But after a few minutes, I got the “temporarily unavailable “ message from the LG Content Store again. Very frustrating!
Hello guys
As an experienced LG Oled TVs I can suggest one option to solve all kind of WebOs function. Since it’s computers I always
unplug the power cord from the wall for few seconds . Usually it fixes all kind of sudden errors with the WEBOS of LG.
Let me know if it solved your issues.
  • 2 months later...
  • 4 months later...
Did you ever find a solution to this problem? I'm an IT guy also troubleshooting the exact same issue for weeks very frustrating!!!
As crazy as this sounds try this, unplug your tv for a few minutes then plug it back in. I’m a computer repair tech and have years of experience in a variety of electronic troubleshooting.
I was having this same issue when I ran across this fix that seemed so silly but it werked!!
Ah yes after twenty years in the computer support industry myself it is amazing how many times the solutions of turning off/unplugging and turning back on again works.
  • Haha 1
Well unfortunately the "unplug from power source" doesn't work for me. I live in South Africa we are currently having scheduled power outages  for +/-  3 hours daily even that prolonged period of "unplugging" doesn't work. What's even more strange/annoying is that the LG content store & all other apps won't work on a wired connection directly connected to my ISP modem/router on FTTH (using Google DNS) but NETFLIX works without a single glitch all the time.  I keep getting the "CHECK NETWORK CONNECTION (-118)" error message on the wired connection.
I'm almost convinced that the wired connection takes second preference to a wireless connection as I can access the content store & the rest of the apps via a cellular broadband connection (without using Google DNS) even though the wireless doesn't work at all on my primary ISP modem/router.  I have put the TV in the DMZ on my  primary wired ISP modem/router to avoid any firewall/port blocking issues to no avail I have even requested for a static public IP address from my ISP.
Is there any way to pull logs directly from the TV via SSH or something? BTW I also got +20 years tech experience but this is just mind boggling & highly frustrating!!
Well, besides the obvious like unplug the netwerk cable or switch it out, there could be a bad connector etc. Also unplugging and powering down are two different things. I’m pretty dumb but maybe there could possibly be enough power to keep the settings, ie:standby power? Perhaps? I would still unplug for 5-10 minutes just to be double sure and while you’re at it swap your netwerk cable out or at least check the fittings/connectors. Good luck!!
  • 1 month later...
Finally this issue is solved for me, for resolution go through the below lines and follow:
I was frustrated for months with similar issue and blamed the ISP for the issue as certain preinstalled apps like youtube etc. worked fine, but LG content store was just not reachable. I had a Linksys E900 wireless router. To my surprise, changing my router made the content store reachable. With this I finally concluded it was my router that was the culprit and not LG or my ISP. I then factory reset my router settings, but it didn't work. What really worked for me was a setting on my router known as MTU (Maximum Transmission Unit Size of Data Packet). It was on Auto Mode and showed a value 1480. I then changed this value to manual mode and with a value 1470. Saved settings, restarted router and TADA it worked. Hope changing MTU size for you guys solves your problem as well. For Linksys routers this setting is under Basis Setup -> Setup Tab. The same setting for your make router if not linksys will be elsewhere, refer to the user guide of your manufacturer for more assistance on tweaking this setting.
All the best Guys!!!
Zap
(happy to help [email protected] )
Pune, India
  • 2 years later...
I have the same problem.  I've tried unplugging  it,  changing  the DNS server, even connecting it to my phone hotspot so I know its not the internet.  My apps work even though some of them keep insisting on being updated which they refuse to do, but now I can't even get in the app store it just says network connection  error code 105.  Any ideas I'm really fried.
  • 8 months later...
Zap
Pune, India
This is the real troubleshooting everyone needs, your solution works wonders!
Thank you
  • 2 years later...
My new 24 inch LG TV will not update software and will not d/l the user agreements.  I have tried every trick I can fond on line, multiple times, to no avail.  Can I assume to issue is somewhere in the internet system in my apartment complex?  btw, is LG the only TV manufacturer that treats its customers like afterthoughts?
    • By Bhanu Kumar
      In today’s fast-evolving digital landscape, technology continues to redefine how businesses engage with their audiences. To stay ahead, companies are embracing innovative content creation methods that deliver immersive, high-quality experiences, capturing attention and driving deeper engagement.
      LG has taken a major leap forward in content production with the launch of its state-of-the-art virtual production studio at its North American headquarters in New Jersey, USA. A potential first in the consumer electronics industry, this in-house content lab empowers LG with advanced tools to produce premium-quality content that reflects its diverse product portfolio, emphasizing efficiency and sustainability.
      At the core of the LG Virtual Production Studio is the company’s award-winning commercial LED display technology, featuring a 1.5mm pixel pitch display spanning two walls. This setup enables immersive, cost-effective and flexible content creation, complemented by cutting-edge technologies from LG’s partners, including the Megapixel HELIOS Controller and Mo-Sys Camera Tracking Solutions/Server.
      Further strengthening its capabilities,
      link hidden, please login to view, a leading developer of virtual production solutions and camera robotics. This collaboration seamlessly integrates LED displays and controllers with Mo-Sys’s XR technology to create a comprehensive XR solution. In the LG Virtual Production Studio, the HELIOS Controller allows multiple users to operate the Mo-Sys Camera Tracking Solutions/Server platform in real time without the need for additional software.
      The studio significantly enhances production efficiency by reducing set build times. Advanced features such as parallax motion and real-time rendering enhance realism and adaptability, offering greater creative flexibility, increased content output and cost savings. Looking ahead, the studio plans to produce episodic content and collaborate with brands, further reinforcing LG’s commitment to innovative storytelling.
      Beyond creative benefits, virtual production reduces the need for costly physical sets and on-location shoots, minimizing environmental impact while streamlining production workflows. This shift helps reduce environmental impact while making content creation faster and more adaptable to a variety of creative demands.
      The LG Virtual Production Studio features a 25-foot, two-wall display constructed from two large 1.5mm pixel pitch LG MAGNIT Studio Series LBAG015-G3 Direct View Micro LED displays, positioned at a 90-degree angle. Despite being a compact 1,000-square-foot space – small compared to conventional studios – this setup delivers limitless creative possibilities with ultra-realistic backgrounds and seamless special effects. Unlike traditional LED displays with wider pixel pitches that require large studios to avoid visible pixels, LG MAGNIT technology enables high-quality content creation within a compact footprint.
      LG’s global in-house creative agency, HSAD, plays a pivotal role in maximizing the studio’s potential, leveraging its cutting-edge tools to craft compelling narratives that resonate with diverse audiences. The establishment of this advanced studio marks a significant milestone for LG, underscoring its commitment to innovation and sustainability in content creation.
      By investing in an in-house virtual production studio, LG is redefining creativity – producing high-quality content faster with less environmental impact and new levels of creative freedom.
      To learn more about Studio Series LBAG015-G3 Direct View Micro LED displays, visit .
    • By MNHL
    • By JamesH
    • By DavidSr
