    • By Calvinder
      One suggestion was to go to Settings>all settings>general>AI Service>Voice recognition service and change to LG ThinQ.
      But the  Voice recognition service tab is gone. There is only voice recognition settings tab
      I would rather not have to reset to factory settings unless there is a way to save / export my current seating's
      Any suggestions
    • By Gene680
      It turns my channel off at random times exactly 11 minutes after the hour. I checked and double checked the settings looking for timers, etc. any fixes that I’m missing?  It’s when I’m streaming on Sling.
    • By Junaid Ahmed
    • By Ganesh R
      Hi LG Team,
      Regards,
      Ganesh R
    • By Flowace
      How do you measure your productivity? Are there specific metrics you use?
