Can't cast youtube to LG WebOS from my MacBook
Hi!
I have an LG Tv with WebOS. And I'm trying to cast youtube videos from my macbook with mac os high sierra to my tv and it doesn't work. Chrome tells me that “No Cast destinations found.”
It works with iPhone though... therefore I don't know what might be a problem.
I've tried different MacBooks and different iPhones. I've tried Chrome Canary with no extensions installed. The result is the same. I've also tried two different routers.
All devices are in the same network and on the same bandwidth (2.4). But it also works when tv's on 2.4 and iPhone's on 5ghz.
Also I can see my TV as a Spotify-connect device from my MacBook.
I have enabled “Load Media Router Component Extension” in flags. chrome://flags/#load-media-router-component-extension.
  • My MacBook is 15-inch, 2017
  • with Mac OS 10.13.6 (17B1003) installed.
  • tv model is:
    with WebOS 3 installed (don't know exact version)
  • Router: ZTE H369A (came with tele2)
Thanks everyone!
    • By Lee Magee
    • By Will M
