Have an LG tv with web OS 2.0 HELP!!!
By ato53
I have a new C4 TV.
Thanks for the follow-up
By John Nguyen
By Rizwan Sumra
By Peter Payne
By WD4512
Did the webos update on 7/28/24-now the TV won’t recognize hdmi port to cable box. Same hdmi cord used as before-not recognizing it. Did the diagnose & said it was a faulty hdmi cable. It doesn’t make sense as it’s the same cable we’ve been using.
Mwira
Is there any app on the Web OS 2.0 that will give me live channels. Like sling, youtubeTV, Hulu live tv or Direct tv live
