I loaded the Cyanogen mod on my Touchpad, now dual boots. I prefer the Ui of webOS but the app catalog of android! webOS need sna android app emulator to tap into that like BB playbook does.
    • By pivotCE
      3. Soldering iron and solder
      2. Items 2-4 above
      1.
      2.
      Prepare the Wires
      Final Thoughts
      #webos4ever
    • By pivotCE
      Tools for the Job
      – Needle nose pliers/tweezers
      – Flush cuts
      – Painter’s and kapton tape
      Trim the USB C Board
      Tape the USB C Board
      Where To Get Power and Data
      Put the Pieces Together
      Congrats, You Now Have USB C
      #webOS4ever
    • By coyote
      I'm surprised by how few Settings there are.  Is there an Android Settings App?
    • By Ayon Mondal
      Whenever I'm trying to run hotstar on my TV it is showing that NETWORK CONNECTION NOT STABLE TRY AGAIN.  Please solve the issue as soon as possible and let me know how to fix it.  This is the serial number of my TV :- 64387205122152TRFLJL
    • By SGray
