Record from app to external hard dick..
1 hour ago, Ghaleb said:
Hello .. i hope somebody can answer on my quistion .. how i can regester from youtube as example from lg oled 55c7v 55"a to externl hard dick.. ??
With best regards
To the best of my knowledge it is only possible to record from a TV source.
  • Thanks 2
    • By mycop
      Greetings.
    • By bos2prov
    • By JamieG
    • By SergeNault
      Hello all, quick question,
      I have an LG Smart TV, with the latest firmware ( 04.50.56), that is connected to a PVR ( Cisco).  That PVR, via a cable company called Videotron,  has about 50 of exercise videos of 20 minutes recorded over that past years.  I wish to move away from my existing TV provider, but before doing so, I'm trying to figure out how to export the videos into an external drive ( USB, cloud) , so that I can re-use them. Some people have suggested to remove the hard drive from the PVR and export to a USB, but those files are encrypted.  So outside of using my Iphone and actually record the shows, is there a better quality way of doiing it?  I'm thinking some sort of app, that the TV can download, and then record to a USB drive for example.  Thanks for sharing any positive outcome.
      Serge
    • By Laurence
      I have an LG65UR80006LJ and when I plug my portable hard drive in to one of the USB ports, it lights up and sometimes the thumbnail folder gets added by the TV (I can see it when I plug the drive back into my PC) and twice now it has operated as expected and it appears as a device on the media app.
      But it has only worked correctly twice and now doesn't find the drive at all, despite me having reformatted it and only add one file to the root directory (the first page if this makes sense; not buried in sub folders.)
      Before I box the TV back up and send it back, is there anything else I need/can do as my 12 year old Philips smart tv has no problems what so ever finding the drive and playing the media on it?
      Thanks in advance for your help.
      Laurence
