I understand why the feature exists.  I will gladly accept resposibility for disabling the feature, knowing the possibillity of burning my screen.
It is NOT ACCEPTABLE to me to spend this kind of money on a high-end television and not be able to do something as simple as display Karaeoke lyrics on it.  Is it possible that the application developers can insert a function that keeps the screen saver from kicking in?
  • 2 years later...
  • 4 months later...
How does a Karaoke app manage to go entirely unattended for multiple hours? Don't people select songs? It's an inherently interactive experience. I don't think it is a great thing for an app to send false user activity indications to the OS. Maybe it could do something when microphones are turned on/off or when people are singing if mechanisms allow.
There's an option now to disable the screen saver, it was added when my 2018 75UJ657A was pushed to 06.00.04. I I noticed a few other things too, like being able to turn off the images it shows when there is no signal. Personally, what bugs me about screensavers on most devices isn't that they happen, but that they show some kind of animation stuff and keep the backlight on. It seems to me that the screen would be best saved by having it just go to sleep like my laptop and phone do.
    • By crct
    • By DWINKS49
    • By Batman
    • By mycop
      Greetings.
