- 1
new to WebOS, two simple questions
By Trev
1. For well over a year the Antenna Channel Guide has been incomplete. Is there a way to manually update the guide?
The Prime app has suffered from two problems:
2. No subtitle option on movies, fixed by app uninstall/reinstall. Is there an easier fix?
3. 4K movies downgrade to SDR or SD momentarily, app uninstall/reinstall did NOT fix this?
TV software is upto date. Internet speed is good. Cache has been cleared by power disconnect/reconnect.
I have not tried Reset To Original settings, will that wipe out antenna channel & HDMI input name customizations?
Thanks.
By Roy Brown
By Khelben Arunsun
By magicschooldropout9
By AmuLulu
foxfire_pt
I like webos on my TV, but there are only two small anoying details that would be great if there is a way around it.
1. TV in Portugal Vodafone has still Cable and Antenna channels. Scanning is not a problem and quality is acceptable for the source. Those channels because they are analogue will not gain description and only show the frequency name such as "S34". Is there any way to rename the channel to something more human readable such as "RTP1" ?
2. Adding a bookmark from the web browser to the main screen works like a charm, but is there any way when lauching the bookmark from there in FullScreen and it doesn't show the intire browser ?
thanks
3 answers to this question
