How do i disable wifi?
There is no option any where in the web OS that is able to diable the wifi. Although I do see in the manual that there is the option while looking at available wifi hotspots you can turn in off. But in my actual TV it doesn't appear.
3 answers to this question
Some LG models typically at the higher end, you can disable wifi. There is a switch that appears on top of wifi. Most LG tvs don't have the switch.. To disable wifi, you have to connect an ethernet cable at the back.
Thank You for your response.  I have a LG 86 SJ957T. I have my ethernet cable currently connected to the back, even so the wifi is enabled. I was hoping there is a way to enter a technicians menu of some sort.
It shouldn't be a problem if both show connected as ethernet is the default networking connection however you can try a possible workaround to the no wifi on/off switch.
1. ensure you have an ethernet connection
2. enter the edit function to your wifi connection.
3. clear all the boxes in wifi connection and exit out. If there is a auto connect checkbox make sure it is unchecked.
If all goes well you should only have an ethernet connection remaining.
    • By NickL
      Br,
      Nick
    • By agus
    • By mycop
      Greetings.
    • By Tunari
    • By Ramesh Chand Vishwakarma
      Regards,
      MD/CEO
      Noida, UP
      +91 9910246766
