Pop up messages on TV:wired LAN disconnected, then Network connected
For the past few months I am getting intermittent pop up messages on my TV.
1st one says Wired LAN disconnected, then another message pops up and says Network connected. I have been calling my cable carrier Spectrum and Techs have been here and can't find problem. Also I went to check my wifi on my TV and my user name and connections aren't showing up all of a sudden. This TV was just purchased May 2017. What is going on and how to resolve!!
5 answers to this question
The TV is 49sj810v .Following the firmware upgrade, the pop up messages are still annoying (no change).  In brief, it displays lan disconnected - connected, unknown device disconnected. Aslo my WIFI stopped working, as well the magic remote control (i have two remotes and none could be registered. Every time that i try to register, it displays Bluetooth has to be initialised. Currently am using a standard Remote control from my older 3dLG television.
Question: Does the bluetooth and wifi modules in this TV related?
It seems that this is the last LG item item that i have purchased. Currently all my TVs and mobiles are LG.
My TV did the same. Model 49UK7550PLA. The Magic remote could not be used as a mouse, only classic buttons were working. In settings, I could not turn Wi-Fi ON.
Problem was wireless card. As TV was connecting and disconnecting device I guess problem was the kernel's IRQ. Device wlan0 was reconnecting and with it also eth0.
I disassembled the TV and find out, that ribbon cables connecting the main board with the wireless card at the bottom of the TV was twisted and tensioned (no idea why, there is plenty of room).
After disconnecting cable on both sides, untwisting and reconnecting it, TV started working properly.
If it doesn't help, maybe you have to replace wireless card or cable.
Good luck guys.
    • By Batman
    • By Kane Murphy
    • By akhil7j
    • By Rayden79
      I'm having this problem with LG Oled 65c16LA with WebOs Version 03.40.85
      When I turn off the TV, it goes into standby mode.
      After 2 minutes the red standby LED turns off and it is no longer possible to turn the TV back on with the remote or with the power on button.
      It is then necessary to unplug the power supply, wait a few minutes and reconnect it.
      So the TV goes back to standby and you can turn it on again. In use everything works.
      Is it a software problem? How can I solve it?
      Thank you
      First in the 5G Private Network Industry to Receive Domestic Network
      Equipment Certification from Korea Association of Network Industries
      SEOUL, Sep. 26, 2024 — LG Electronics (LG) is stepping up its presence in the 5G private network market, a key infrastructure for future industries. The company has recently achieved a significant milestone by becoming the first in 5G private network industry to receive the “Domestic Network Equipment Certification” from the Korea Association of Network Industries for its self-developed 5G private network solution.
      The “Domestic Network Equipment Certification” is awarded to products that are developed and manufactured in South Korea, a key credential for supplying to public institutions. This certification marks LG’s official recognition for internalizing core 5G private network technologies.
      A 5G private network is a customized network deployed in specific areas like factories and buildings, offering high-speed data transmission and exceptional stability. It serves as a vital foundation for innovations such as digital and AI transformation (DX/AX) and smart factory operations.
      LG’s certified 5G private network solution leverages advanced software to handle network functions typically managed by traditional 5G equipment like Radio Access Network (RAN) and 5G Core. This software-based approach allows for faster data processing and improved stability, with the added benefit of enabling upgrades without hardware replacement, significantly lowering operational costs.
      Harnessing its strong software capabilities, LG’s solution delivers a customized 5G private network tailored to meet diverse client needs and installation environments. For instance, it can create secure, isolated networks for clients with high-security requirements or integrate external cloud services for companies that require frequent collaboration with external partners.
      In addition to network setup, LG’s solution offers a device control platform for seamless management of connected devices. This includes LG’s own products, such as robots and digital signage, as well as clients’ existing equipment like CCTV and smart safety devices, all integrated via the 5G private network.
      With the momentum from this domestic certification, LG plans to actively pursue both enterprise-focused and public 5G private network initiatives, targeting sectors like smart factories and more.
      Recognizing the immense potential of the 5G private network market, LG has committed significant resources to technology development. The company holds around 30,000 telecommunications patents, including many related to 5G, ranking it among the world’s top innovators. Last year, LG formally added “facilities-based telecommunications business” to its portfolio, positioning itself for full-scale commercialization of its 5G solutions.
      LG also brings extensive real-world experience, having tested its 5G private network solution at various reference sites, including its Tennessee factory, a smart factory in Chungbuk, a logistics center in Incheon and a university hospital in Seoul.
      The global 5G private network market is expected to grow rapidly, from approximately USD 2 billion in 2023 to around USD 11.8 billion by 2028, with a projected annual growth rate exceeding 40 percent, according to market research firm MarketsandMarkets.
      “We will continue to provide customized 5G private network solutions for clients who need fast, stable networks, leveraging our outstanding 5G technology and operational expertise, accumulated in various sectors such as factories, logistics centers and hospitals,” said Lee Jun-sung, vice president and head of LG’s Private Network Business Development Department.
