  • 1
Application has not been installed. Please try again
3 answers to this question
Easy fix folks.
Go into your network settings.
Click on whichever connection your have (wired or wireless connection )
Scroll to the bottom and select edit
uncheck set automatically
change the DNS server to 8.8.8.8
click connect and bam you’re good to go
    • By Michael Hirons
    • By Jaswinder Sandhu
    • By ato53
      I have a new C4 TV.
      Thanks for the follow-up
    • By u84six
    • By Calvinder
      One suggestion was to go to Settings>all settings>general>AI Service>Voice recognition service and change to LG ThinQ.
      But the  Voice recognition service tab is gone. There is only voice recognition settings tab
      I would rather not have to reset to factory settings unless there is a way to save / export my current seating's
      Any suggestions
