Streaming 4K content with high bitrate
Hi.
I've got a LG OLED C7 with smart IP TV app. I'm having trouble watching 4k movies with high bitrates ( some movies have bitrates higher than 80mpbs). I already connected the TV with wifi AC (5Ghz) instead of ethernet connection (which has only 100mbps port).
My internet connection has a speed of 200mbps (tested on tv browser).  Nevertheless I'm struggling playing those 4k high bitrate movies. Every few minutes it buffers.
What can be the problem? The TV plays high bitrate movies from USB or bluray and the internet speed should be enough for those bitrates.
 Is it possible to install a gigabit ethernet port in the pcmcia port?
Thanks for your help.
9 answers to this question
  • 1
The simple answer is no, but as long as the bitrates do not top 100mbps then the standard network card would do fine.  So you could at least do some testing with a cable to see if the issue is with the WiFi itself or something else.  That said the AC wireless card in the TV should be more than equal to the task you are asking of it.
What source are you trying to stream from?
Are you streaming directly from the modem/router to the TV?
Is anyone else in the house using the network when the buffering occurs?
  • 1
5 minutes ago, bfds89 said:
I'm using SMART IPTV app with an iptv list.
The service provider already guaranteed that the server is more than capable to share media through internet.
I also tested playing movies through usb pen with success. Initially I was connected  with ethernet port, but experiencing buffering issues, so I decided to connect with wireless so I could achieve more speed (around 200mbps).
Basically I'm trying to stream High bitrate 4K movies (Bluray quality) through internet with no success (buffering from time to time), but I already guaranteed that the problem is not with the server and also by connecting with a speed that is superior than the bitrate of the movies.  Also the 5GHz band is used exclusively by the TV with no interference from the neighborhood, since they use only the 2.4GHz band.
If I could use a PCMCIA card with gigabit connection it would be great.
So you have experienced buffering on both wired and wireless connections?
Just because the content provider's server is capable of streaming 4K and you connection can hit a peak that should be good enough, there are a whole lot of things between them and you that can cause issues.
I was not thinking of interference with the 5GHz WiFi, but more people using the local/house network.  For instance Windows does have not bandwidth restrictions so if someone downloaded a file while you were streaming Windows will potentially hog all the available bandwidth.  Some modem/routers offer bandwidth quotas for devices, this would help prevent such a problem.  Another things to think about is whether the modem/router has the latest firmware installed.
If you know someone with a suitable Netflix account (or any other service with 4K content) and would let you use their details you could stream a 4K video with them to see if you had the same issue.
Just now, nemilose said:
Did you test the same stream on a computer with gigabit ethernet?
Well yeah. but I guess my laptot ASUS K550JX with a i74750HQ and a nvidia geforce gtx950m is not enough to run movies using HEVC codec with high bitrate, the movies displays lots of artifacts when watching on PC.
4 hours ago, bfds89 said:
Yes, with wired connection I though it was of the bottleneck of 100mbps port so I changed to Wifi AC.
The TV is the only equipment using the 5GHz network in my household.
I have a Netflix account and it works flawless, but Netflix doesn't stream high bitrate movies,  I think the bitrate of netlflix is around 20-25mbps so this work well.
I remind you that the content I'm trying to stream has bluray quality with very high bitrates.
Yes I get that you are trying to stream hit bitrate streams, but no I did not know about the Netflix bitrate.
When it comes to the WiFi I am not suggesting that something is interfering with the signal, more that is there anything else on the 2.4GHz/wired networks that are using bandwidth?  The traffic is going to pass through the same modem router at the end of the day.
Do you have access to an alternative modem/router for testing?
as i assume you are trying to stream the high bit rate video from a remote server, can i know your internet speed?
do you have any idea about the video bit rate of the 4k video
secondly, the pcmcia card cannot use for extending system capabilities. Its just a card slot to add subscription cards for satallite channels ( scrambled channels) also part of some regulatory laws.
4K Blu-Ray maxes out at 128 Mbit/s. I 99.99% guarantee your IPTV service is not outputting at anything close to that bandwidth. If they *are* sharing movies at anything close to that bitrate I also 99.99% guarantee it is pirated content. Don't try to have your cake and eat it too; just buy a 4K Blu-Ray player, invest in some discs, pay a legitimate price for content and enjoy top quality without buffering.
  • -1
  • -1
    • By NickL
      Br,
      Nick
    • By Bhanu Kumar
      In today’s fast-evolving digital landscape, technology continues to redefine how businesses engage with their audiences. To stay ahead, companies are embracing innovative content creation methods that deliver immersive, high-quality experiences, capturing attention and driving deeper engagement.
      LG has taken a major leap forward in content production with the launch of its state-of-the-art virtual production studio at its North American headquarters in New Jersey, USA. A potential first in the consumer electronics industry, this in-house content lab empowers LG with advanced tools to produce premium-quality content that reflects its diverse product portfolio, emphasizing efficiency and sustainability.
      At the core of the LG Virtual Production Studio is the company’s award-winning commercial LED display technology, featuring a 1.5mm pixel pitch display spanning two walls. This setup enables immersive, cost-effective and flexible content creation, complemented by cutting-edge technologies from LG’s partners, including the Megapixel HELIOS Controller and Mo-Sys Camera Tracking Solutions/Server.
      Further strengthening its capabilities,
      link hidden, please login to view, a leading developer of virtual production solutions and camera robotics. This collaboration seamlessly integrates LED displays and controllers with Mo-Sys’s XR technology to create a comprehensive XR solution. In the LG Virtual Production Studio, the HELIOS Controller allows multiple users to operate the Mo-Sys Camera Tracking Solutions/Server platform in real time without the need for additional software.
      The studio significantly enhances production efficiency by reducing set build times. Advanced features such as parallax motion and real-time rendering enhance realism and adaptability, offering greater creative flexibility, increased content output and cost savings. Looking ahead, the studio plans to produce episodic content and collaborate with brands, further reinforcing LG’s commitment to innovative storytelling.
      Beyond creative benefits, virtual production reduces the need for costly physical sets and on-location shoots, minimizing environmental impact while streamlining production workflows. This shift helps reduce environmental impact while making content creation faster and more adaptable to a variety of creative demands.
      The LG Virtual Production Studio features a 25-foot, two-wall display constructed from two large 1.5mm pixel pitch LG MAGNIT Studio Series LBAG015-G3 Direct View Micro LED displays, positioned at a 90-degree angle. Despite being a compact 1,000-square-foot space – small compared to conventional studios – this setup delivers limitless creative possibilities with ultra-realistic backgrounds and seamless special effects. Unlike traditional LED displays with wider pixel pitches that require large studios to avoid visible pixels, LG MAGNIT technology enables high-quality content creation within a compact footprint.
      LG’s global in-house creative agency, HSAD, plays a pivotal role in maximizing the studio’s potential, leveraging its cutting-edge tools to craft compelling narratives that resonate with diverse audiences. The establishment of this advanced studio marks a significant milestone for LG, underscoring its commitment to innovation and sustainability in content creation.
      By investing in an in-house virtual production studio, LG is redefining creativity – producing high-quality content faster with less environmental impact and new levels of creative freedom.
      To learn more about Studio Series LBAG015-G3 Direct View Micro LED displays, visit .
    • By MNHL
    • By Ahmad Baeisa
