By JamesH
By DavidSr
By Fredrik Andersson
By akhil7j
By Muser
- 5,003 views
nicobdx
I will try to make it short.
I have a server abroad (Europe) which I use to upload/download with my family. This server also stores my film collection.
I have moved to the US and the server remains in Europe. Therefore I am trying to be able to stream a movie in the US from the server in Europe via my LG smart TV (LG Oled 55 B7A). When I go on the web interface of the server on my tv to access a movie, it tells me I cant download from there. How can I stream (not download, just stream) a movie on my TV from my server located in Europe?
Seems simple (in principle) but can't find a way.
Thank you
