WiFi is turned off
By agus
By Ramesh Chand Vishwakarma
Regards,
MD/CEO
Noida, UP
+91 9910246766
By Guest
Things that I've tried:
factory resetting the tv leaving the tv unplugged to delete cache using google's DNS on the TV using a wired connection Having said so, I am so lost that I would be happy to try anything again.
By loafty
Tv connects to wifi and can stay connected for couple of days then I will switch tv on and internet (wifi) will be disconnected so go to connect up again and tv can't find any networks so turn off and unplug from power wait 5 to 10 minutes then plug all back in go to wifi settings might be lucky to find my network select and enter password and works again. Only thing is I got a different modem from internet provider and they have told me that the modem is working fine but I have never had an issue like this with tv before. Tv states wifi is turned off but I can't find anywhere that I can turn wifi on in the tv, does anyone know ?? Tried calling LG didn't get much help at all, I am 71 years old and just want my tv working the way it should so hope someone can help. Thanks
Akshata Shinde
In the network option for Wi-Fi connection I'm unable to see the ON/OFF option for the wifi connection. The message says "Wi-Fi is turned off. Turn it on to see the list of available networks that you can connect to and additional related menu items".
As this has previously happened for which I had to call the customer service for which they had sent an associate for that after which it worked properly. If that problem had been fixed then why this issue/problem occurred again?
Kindly help me to understand what should be done in this case.
Thanks in advance
