Good morning,
Smart IPTV app is installed on my LG tv and I would like to make this app as my "default" quick start app when I turn on the tv.
Now, the tv is always restarting with the antenna channels, and I want the same with this app.
How can I do that ?
Thank you,
Have a good day,
    • By ironmonkey
      Just bought an LGLED-65UJ630 65INCH TV. Right away I started to get the message "This app will now restart to free up more memory". After searching the internet and forums, I now understand that this problem is huge, it has been going on for years now and it is right across many models of LG TV's.
      I have tried everything to fix this problem. It has the latest firmware. I did the factory reset and that lasted 4 hours before I got the message back. I turn off the TV and leave it for 10 minutes, maybe one hour later I get the message. I delete browsing history, maybe 10 minutes and I get the message..... you get the message.
      As I understand it, the problem is that LG TV's don't have enough internal memory, but they have shipped a ton of their "smart" TV's with this problem.
      My question is, has anybody heard anything from anybody, anywhere about a solution to this problem. I really want to keep this TV, but it is not fit for purpose in this state.
    • By Puja aingh
      Dear LG TEAM
        Kindly resolve this issue
      My lG TV MODEL NO IS 32LK628BPTF
    • By Cedric
      Since my TV updated to the last WebOS firmware 05.20.08, quick access key (Long Press 1 for HDMI1, Long press 2 for HDMI2) are reset each time i shutdown the TV, and i have to set them after each reboot...
      I tried to restore the factory default settings on the TV to see if there is any change, but sadly this didn't fixed my problem.
      Any idea please ?
    • By Ceapa Adrian Emil
      Hi guys! I have a 55QNED81QA and my question is this:
      After software update, how do i restart the webOS without unplugging the TV from outlet ? I don't see a restart option in the menu !
