- 2
Player problem
By Jack1151
By Venkata
Hello Team,
By PVD
By hollean
By AJO
- 1 answer
- 3,590 views
Luis Araos
I used to cast from ace stream directly to my UJ6300 and I had no problems until a few days ago when the TV got an update for WebOS 3.7 I think. Now whenever I try to cast to the TV it just shows a black screen on the "Web App Viewer" app, I was wondering if maybe I could set a different player as default player when streaming from my phone instead of the Web App Viewer, as when I play from other sources it starts the "Photo&Video" player.
Otherwise I think I would have to downgrade the OS to the previous stable version.
Anyone else having this problem?
11 answers to this question
