By Cedric
Since my TV updated to the last WebOS firmware 05.20.08, quick access key (Long Press 1 for HDMI1, Long press 2 for HDMI2) are reset each time i shutdown the TV, and i have to set them after each reboot...
I tried to restore the factory default settings on the TV to see if there is any change, but sadly this didn't fixed my problem.
Any idea please ?
By pattox
It is easy to add a new item to the quick settings side menu on an lg c2, as long as the item you want is shown on the list presented when you choose the + add item. If you want to add a "shortcut" to an item that is not on the list then how can that be done. Is it possible to edit the list presented?
Specifically I want to add a shortcut to "subtitles on" which is buried deep in accessibility settings, there nothing on the list of options presented to allow this.
By eks1910
I'm trying to figure out how tp add and remove content/devices from the "Quick Card" section of the "Home" screen on my UR9000 smart TV.
The attached photo shows what it looks like, and I would like to remove "Sports", "Home Office", "Game", and "Music" and replace them with inputs devices that I can quickly access, like "HDMI FireTV", HDMI DVD-Blu-Ray", and "Antenna"
Does anyone know how to edit this so I can add all those so they all show up on my "Home" screen?
By Bazzer
Hi All, i have a small problem on my new LG 32LQ631C0ZA Full HD SMART TV. I have connected a WD 2TB My Passport to the USB drive, but cannot get it registered for a 'Quick Access'. It is formatted to NTFS. I had no problem with the previous LG TV, which wasn't SMART. Any suggestions Guys, thank you, Barry.
By BVinDR
LG 43UQ7590 used as photo display. Put it into Hotel Mode and set IR Operation to Block All. This is to prevent the photo display from responding when I turn my main LG TV in the same room on and off. All OK. Then wanted to turn off Hotel Mode so entered the 1-1-0-5 sequence again. But did something wrong as now the Quick Access settings menu comes up. I can't exit that menu since the remote is blocked. Tried unplugging TV for a day - still the Quick Access menu comes up. Tried inserting a USB drive with updated firmware for the TV but can't select the Yes/No options to continue the update. Is my only hope getting a service remote? Thanks much.
retireandgo
LGOLED C8 - It powers on, I get a quick “webOS” and then the screen goes black again. The remote has new batteries. This is just after getting it out of the bos and the stand attached. What is going on?
