This is quite an old topic...
But the fact that it can be done is now quite evident by the partnership Samsung Hue
Search for Hue Sync TV app
Only for Samsung newer models
11 hours ago, Palu said:
這是一個相當古老的話題......
但現在可以通過三星 Hue 的合作夥伴關係來證明它可以做到這一點
搜索 Hue Sync TV 應用程序
僅適用於三星較新型號
Yes still no good news in LG
  • 1 month later...
  • 3 weeks later...
  • 2 months later...
On 7/31/2023 at 12:04 PM, Rantakemisti said:
They are cutting this feature from their own Philips Ambilight TVs, so I'm sure that we will not see this in LG's.
Oh no....that is a bad news..i may change brand also don't like setup cam on the tv top.
Btw, thx
Ps : can leave lg forums. .!
  • 1 year later...
On 1/11/2023 at 6:40 PM, Rantakemisti said:
Yes they have released an app for Samsung TV's, but the price is insanely high. I mean Ambilight was a very nice gimmick but I'm not sure if I'm willing to pay $130 for an app that just controls my lights.
What is even more unreasonable is that this software needs to be bound to the TV, and the TV hardware cannot be replaced again. So if your TV is broken or you buy a new TV, this software can no longer be used. If the underlying OS system can output color information (APIs), it can protect the copyright of the content and support more light strip equipment manufacturers to join the competition. App developers only need to adapt to the control protocols of various brands of light strips to link with LG TVs. This is the correct development direction of LG TV ecology!
  • 2 weeks later...
It's 13th March 2025 and the Hue Sync app is now available for the 2024 models, i.e. C4, G4 but not earlier ones.
6  months ago I purchased a C3 so I'm really annoyed I can't get this app.
What is the best way to ask LG if they ae bringing it to older models?
    • By Kane Murphy
    • By Flavio_S
    • By valoufifa
      I’m French sorry for my poor english
      I was wondering if it’s possible to disable simplink (or only auto sync on) only on 1 HDMI device.
      I have an LG C1, multiple HDMI devices which work perfectly with simplink, except an LG Blu-ray 4K player (UP970).
      When I turn on a device, it turns on the TV, great! But if the Blu-ray
      player was the last device I used, and I turn everything off, and then
      I turn on a device, the TV then turns on and shows first the HDMI
      Blu-ray player input (with no signal), then it shows the HDMI input of
      the device I turned on, and finally the Blu-ray player turns on and
      the TV switches back to the HDMI Blu-ray player input...
      Any ideas on how to fix this?
      Thank you!
    • By Jei
      I have LG 65C1,  Denon x4300h(arc monitor 1 was broken, but monitor 2 is working ),
      and what I would like to know is,
      can LG TV's autopower sync works?
      I mean I want to turn on TV using  the LG remote control,
      then my Denon x4300h could turn on automatically,
      when I turn off TV, then Denon turn off automatically.
      I tried many ways to test it, I open all the functions about hdmi control, hdmi cec, simplink, autopower sync...
      but it still doesn't work,
      how could I solve it?
      Or LG TV  just can't do it?
      Thanks a lot!
    • By SnarF007
      Does WebOS 6 have the power sync option?
