- 1
OLED65C8PUA lip sync
By informatiko
By Kane Murphy
By Flavio_S
By valoufifa
I’m French sorry for my poor english
I was wondering if it’s possible to disable simplink (or only auto sync on) only on 1 HDMI device.
I have an LG C1, multiple HDMI devices which work perfectly with simplink, except an LG Blu-ray 4K player (UP970).
When I turn on a device, it turns on the TV, great! But if the Blu-ray
player was the last device I used, and I turn everything off, and then
I turn on a device, the TV then turns on and shows first the HDMI
Blu-ray player input (with no signal), then it shows the HDMI input of
the device I turned on, and finally the Blu-ray player turns on and
the TV switches back to the HDMI Blu-ray player input...
Any ideas on how to fix this?
Thank you!
By Jei
I have LG 65C1, Denon x4300h(arc monitor 1 was broken, but monitor 2 is working ),
and what I would like to know is,
can LG TV's autopower sync works?
I mean I want to turn on TV using the LG remote control,
then my Denon x4300h could turn on automatically,
when I turn off TV, then Denon turn off automatically.
I tried many ways to test it, I open all the functions about hdmi control, hdmi cec, simplink, autopower sync...
but it still doesn't work,
how could I solve it?
Or LG TV just can't do it?
Thanks a lot!
- 5 replies
- 6,188 views
jkitc
Please tell me how to sync audio and video on my OLED65C8PUA TV.
