TLS fatal error
I have an LG Infinia 55LW6500 smart TV (https://smile.amazon.com/gp/product/B004OVEVP6/ref=oh_aui_search_detailpage?ie=UTF8&psc=1) that I bought in 2011. Today is the first time I tried searching the internet using its built-in browser, and I can't make it work. The network connection is fine, and it's hard-wired in. I can use Google, and it will show me the results of the searches I've tried. But then when I click on a website URL (or type in the URL), I get the error "TLS fatal error".
Does this have to do with the website security? Is there anything I can do to fix this short of buying a new TV (not going to happen)?
I'd like to be able to watch my Amazon Prime shows directly on the TV without having to hook up my laptop to it. I was thinking of buying Hulu, but it seems I'll have the same problem with it.
Never mind.  I think I got it by updating the firmware.
It's super slow, though. And when I get to the Amazon Game of Thrones page for Season 6, which I purchased and am re-watching with my daughter, there's no place on the TV screen to click to make the videos play.
Any suggestions for that?
    • By Marko00
      only with cancel button.
      How to fix it?
    • By leader6234
      Hey guys !!!
      Thanks in advance !!!
    • By Muser
    • By geoffHome
      Reset our router (turn off then turned on again  and waited) but now no networks are even found to attempt to connect to.
      Any suggestions what my next step should be?  This has happened suddenly.  Thanks
